Brake Master Cylinder Adjustment Procedure
Old Apr 1, 2009 | 02:25 PM
11:11's Avatar
Default Brake Master Cylinder Adjustment Procedure
I'm going to be installing a new brake master cylinder this weekend, and was wondering if anyone follows the exact procedure outlined in the Helms factory service manual regarding pushrod clearance adjustment? Do the master cylinders you buy from autozone, advance, napa, come pre-adjusted?
Old Apr 1, 2009 | 05:51 PM
BLKFLSH's Avatar
Default Re: Brake Master Cylinder Adjustment Procedure
The push-rod should be the same length as the original. If the store gives you the right part, it will be. If it's not the same, adjust it, or return it for one that is.
ilvi3tkidxx
Oct 16, 2008 06:51 PM
RedneckRicer
Jul 15, 2008 01:08 PM
ProjectJDMCRX
Mar 27, 2007 05:02 AM
Geezer
Oct 6, 2003 06:23 PM
