How do you guys get to the TB Tensioner bolt?
Old Apr 1, 2009 | 01:28 PM
Volkspeed's Avatar
Default How do you guys get to the TB Tensioner bolt?
I am about to finish changing the head gasket on my stock D15B2. I need to loosen the tension on the belt so I can put it on the cam gear of course. I can see the bolt though the hole in the lower timing belt cover, but how the hell do you guys loosen it up? I have big *** hands, a normal 3/8 ratchet and normal 14mm socket. What would be the best way to get to this?
Old Apr 1, 2009 | 01:45 PM
iwanttokillgod's Avatar
Default Re: How the hell do you guys get to the TB Tensioner bolt?
breaker bar or extension its not that hard just some common sense
Old Apr 1, 2009 | 02:09 PM
jdmwannabee's Avatar
for some reason I'm supposing your trying from the top... take the wheel and fender liner out and have at it.
Old Apr 1, 2009 | 05:02 PM
sde780's Avatar
I have the lower timing belt cover off and it's pretty easy to get to.
I can't get it with a wrench though, but a 14mm socket and a smaller socket wrench did the job fine, you don't have a lot of room though.
Old Apr 1, 2009 | 05:58 PM
Volkspeed's Avatar
After scraping most of skin off my knuckles, I did it though the top. I figured that using a breaker bar would have been the easiest way, but I did not have a breaker bar at hand. Just what I had mentioned before, some big *** hands, regular ratchet and regular 14mm socket. Please bare with me as this is my very first Honda ever coming from Mercedes diesels. I think im going to love Hondas.
Old Apr 1, 2009 | 06:29 PM
sde780's Avatar
Yeh I scraped skin off on every finger today when I changed the timing belt, they all get infected too
Old Apr 1, 2009 | 07:17 PM
89s1's Avatar
infected??
dayum, I havn't had a cut get infected since I was like 11.
pour something that stings like a ***** on there, grit your teeth and you'll go away with a scar (for the ladies) and thats it.
Old Apr 1, 2009 | 10:19 PM
crxcess's Avatar
move as much stuff out of the way on top. even then, you don't get many notches at a time with a socket wrench.
clindberg86
29
Jun 26, 2014 08:51 AM
dephtone
Dec 1, 2008 06:59 AM
BringIT
Dec 1, 2003 08:08 AM
JLange
Sep 25, 2003 07:53 PM
b17gsr
Feb 11, 2003 07:46 PM
