Help with d16z6 is a 88 si cel
Old Apr 1, 2009 | 07:44 AM
Loading.....'s Avatar
New User
Default Help with d16z6 is a 88 si cel
Hello. I have a CRX Si with a d16z6 in it and it is throwing cel codes 6 7 and 16. 6 is ect sensor, 7 is TPS and 16 is fuel injection. Now I put in a new ect and tps and those 2 still light up. Also There is some rich fuel smelling smoke comming out of my tail pipe and VTECH is in limp mode, I can't rev past about 6100 6200 and stops pulling at 5000. Help! I have a p28 in it and a obd0 to 1 converstion harness.
Old Apr 1, 2009 | 07:49 AM
crxblues's Avatar
Default Re: Help with d16z6 is a 88 si cel
did u switch the wires on the tps? im assuming your using the obd1 injectors without the resistor box. right?
Old Apr 1, 2009 | 10:32 AM
dephtone's Avatar
Make sure that you remove the neg battery cable for like an hour, to reset the ECU to make sure it's not throwing stored codes.
Old Apr 1, 2009 | 02:08 PM
New User
An hour? I thought it was only about 10 sec.? I will giv it a shot. And the injectors are obd1. They have a gray plug that is in them. Thanks for the help I am really new to this.
Old Apr 1, 2009 | 08:51 PM
New User
What do you mean by switch the wires.
EF_Tovi
Nov 6, 2010 07:20 AM
JDM_HAMSTER
Jul 9, 2010 12:38 PM
eg831
Feb 16, 2010 06:26 AM
Rease3
Jun 10, 2008 03:42 AM
wfocrx
14
Jun 19, 2006 08:57 PM
