Mid-Atlantic (Sales) VA, DC, and MD
FS:GSR Brake Swap Complete ++
Old Apr 1, 2009 | 04:51 AM
crowe's Avatar
Default FS:GSR Brake Swap Complete ++
Off of 97 Gsr will of course need rotors and pads like any swap your gonna buy. I am including pads and whatnot but I wouldnt use them. Includes Front and Rear Knuckles calipers 10.3" rotors and of course the rear trailing arms and compensator arms for front. Includes proportioning valve as well as 15/16" master cylinder and brake booster, the 15/16 will allow you to use your stock lines if you chose. Also throwing in gsr front swaybar. Only thing needed is e-brake cable. Id also recomend that you switch out the bushings w./ energy suspension or w/e you perfer. It is 12 year old rubber at this point and will improve the ride. If your gonna do it do it right first time and save later!
$300 Will not seperate
Support my build! Help your car stop!
crazicaveman
Mar 23, 2008 02:36 AM
crxman1983
May 23, 2007 01:14 PM
jugodmyko
11
Mar 12, 2007 12:26 AM
Yellow Dragon
Jun 7, 2001 08:15 PM
