california state ref/bar'd help
Old Mar 31, 2009 | 10:36 PM
99DC2GSR's Avatar
Default california state ref/bar'd help
has anyone ever tried to bar/ref'd a 88-91 civic dx(b18a1) with mpfi wiring and passed? or did you folks just use the stock wiring integra engine harness? i would like to know what needs to be done in order to get the car bar'd/ref'd... and also when doing the b18a1 swap do you use the two purge valves off the integra because on the civic there is only one? these are the black solenoids valves on the firewall of the integra which runs two vacuum hose to the intake manifold... to which as the civic only has one... thanks for the info.....
Old Mar 31, 2009 | 11:07 PM
crx_si-r's Avatar
Default Re: california state ref/bar'd help
Yes both purge solonoids are required for state referee. No you do not use the integra wiring, you either convert to mpfi using your stock harness or find an Si (equivalent year 88-89 or 90-91). Pretty much make your underhood set up look like a teggy.
Old Mar 31, 2009 | 11:08 PM
crx_si-r's Avatar
My 90 Crx is state reffed and I also got my buddies Crx state reffed both with b18A's
Old Apr 1, 2009 | 06:40 AM
99DC2GSR's Avatar
can u post up a pic of where u mounted the two purge solenoid valve? i was thinking maybe just remove the old one and use the teggys in place and jus flip the connector and run longer vac hoses... but, yeah a pic of how u did urs would be great.. thanks for the info...
lindseyhunt1090
Dec 31, 2015 05:22 AM
silverstar4life
23
Mar 1, 2012 10:04 PM
slammedef06
Dec 29, 2005 10:42 AM
Tbindas
Jan 9, 2005 08:24 PM
SyLee Duk
Nov 27, 2002 11:22 PM
