Valve Adjustment Screw removal
Old Mar 31, 2009 | 07:59 PM
v1crattlehead's Avatar
Default Valve Adjustment Screw removal
Hey guys. Two valve adjustment screws sheared off from the intake side of my B16A. Does anyone know what the procedure to removing those are? I know they don't come out from the top because I tried unscrewing it until it hit the shank and it wouldn't go anywhere. So I'm guessing the screw comes out from the bottom... but do I have to take off the whole rocker assembly for that?
Thanks for any help!
Old Mar 31, 2009 | 08:04 PM
blkb18's Avatar
Default Re: Valve Adjustment Screw removal
This may be a stupid question but: Did you loosen the nut first before you tried to turn the screw?
Old Mar 31, 2009 | 08:18 PM
lol Yes.
Well the top portion that has the nut is the part that sheared off. So I only have 1/2 an adjustment bolt without a nut.
I tried removing an undamaged screw by removing the nut and turning the screw both ways until they stopped turning.
Old Apr 1, 2009 | 08:56 AM
So nobody knows?
Old Apr 1, 2009 | 09:30 AM
champLSinteg's Avatar
Just replace that rocker arm. Thats what I did when I head I picked up was missing the nut on one of them.
Jota
Engine Machining & Assembly
13
Apr 10, 2016 03:02 AM
Alex Goodman
Jan 29, 2005 11:45 AM
HulkSmash
Apr 12, 2004 10:40 AM
alexo49
Nov 6, 2003 03:34 PM
