wont start please help......
Old Mar 31, 2009 | 06:42 PM
acevedo's Avatar
Default wont start please help......
heres the deal I have a d16z6 in a 90 civic.It had a TD-02u dizzy I took it off and put a TD-42u and my car wont start.I have a obdo jumper to obd1 but my car wont start with TD-42 can someone help me out.my ECU is a pr3
Old Apr 1, 2009 | 11:02 AM
dephtone's Avatar
Default Re: wont start please help......
I am assuming that the pr3 is odb1, are you getting spark to the new distributor? Is the td-42 a new or used dizzy? The coil might have went bad if it's used. Are you sure your conversion harness for your dizzy plugs are correct? Did you do them or is the harness purchased from a reputable company?
Old Apr 2, 2009 | 05:51 AM
acevedo's Avatar
the pr3 is obdo.The jumper i bought it.I think it might be my ecu.If I put that old distributor on the car will fire right up.The old dizzy is also obdo.
Old Apr 2, 2009 | 06:15 AM
dephtone's Avatar
It's because the td-42 is an obd1 dizzy atleast according to the part sites and thats why the car wont fire. You are using an obd1 dizzy with an OBD 0 ECU. If you pickup a p28 with a obd1 conversion harness you will be set to go.
Old Apr 2, 2009 | 07:02 AM
MonkeyMagic's Avatar
need to match the ecu's obd to the dizzy's
they use a different number of triggers on obd0 and obd1 for the position sensor
Pancho2193
Mar 2, 2013 06:35 AM
No0by
Apr 18, 2012 09:34 AM
efjones9
23
Jan 17, 2009 04:20 PM
cwf1988
Jan 3, 2009 02:11 AM
G2integra217
May 8, 2005 11:39 PM
