Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
headlight condensation
Old Mar 31, 2009 | 06:18 PM
batzcivic's Avatar
Default headlight condensation
when i got home from work i noticed that my headlights have condensation on the inside. my car is an si coupe. will warranty cover this or do i have to buy new ones..i heard of this happening to older cars but mine is an 06. is there a quick fix for this?
Old Mar 31, 2009 | 06:45 PM
FijiBlueFG2's Avatar
Road House
Default Re: headlight condensation
Remove headlights.
Bake them open.
Wipe off and clean inside(for posterity, the moisture will be gone)
Re-seal headlights with a silicone-based sealant.
Old Mar 31, 2009 | 07:05 PM
vladd's Avatar
i'd say take it to the dealer if you still have warranty. no point of wasting your time and money if you don't have to by fixing it yourself.
Old Mar 31, 2009 | 07:19 PM
teggsr925's Avatar
i wonder if a dealer would replace them tho?
but resealling them would be an easy fix
Old Mar 31, 2009 | 07:22 PM
vladd's Avatar
if he still has warranty, then why not? if the headlights have never been messed with then it's obviously a manufacturing defect. however, with his car being an 06 the 3 years might already be up. with no warranty, some silicon should fix the problem. he probably doesn't even need to open them up; just run a line of silicone all around the seal and dry them out.
Old Apr 7, 2009 | 08:14 PM
spooge24's Avatar
How do you go about baking the lights open, anyway? I was thinking of removing the orange inserts and the dead fly from my tail lights...
Old Apr 8, 2009 | 08:50 AM
Zeusone's Avatar
you remove the light and place it in the oven.
Old Apr 8, 2009 | 12:19 PM
teggsr925's Avatar
leave it in the oven for like 5 mins at 275*
Old Apr 10, 2009 | 10:59 AM
tek24's Avatar
can you still use the over after that or will it be contaminated with plastic?
Old Apr 10, 2009 | 10:31 PM
striker_18's Avatar
take your bulb out and give it some air. Chances are, you have a pnp kit in there.
Old Apr 11, 2009 | 07:23 AM
Road House
The plastic won't melt, (hopefully), but the glue holding the headlight housing together will.
Old Apr 11, 2009 | 09:56 AM
miketat594's Avatar
if you dont want to bake them , go and get yourself a cheap heat gun and do them that way, also worth having a heat gun if your lights have that sand blasted look . with some heat you can heat them up and smooth out the pitting from road grime and make them look clean again, if you do it with a soft buffing cloth , like an eye glass cloth they come out nice.
imzjustplayin
Lighting
Jul 10, 2009 03:16 PM
Slow_EK9
Dec 5, 2008 04:41 PM
agati
Honda Civic (2001 - 2005)
Oct 28, 2008 01:06 PM
SIcivicHATCH
Jan 13, 2005 05:57 AM
jond
Jan 7, 2004 11:12 AM
