Lighting HID/Xenon kits, Retrofits and Associated Topics
For those if you with yellow fogs...
Old Mar 31, 2009 | 09:00 AM
LFSoccer2k6's Avatar
Default For those if you with yellow fogs...
Do you think a 3000K HID kit it better or the Yellow 2500K PIAA bulbs? Pics would be great too. What are pro and cons? Thanks.
Old Mar 31, 2009 | 06:35 PM
CarbonizedDX's Avatar
Default Re: For those if you with yellow fogs...
My buddy has yellow lensed housings on his xterra, he's currently running 3000k's in them and the output is a very strong yellow with a hint of amber... Are the housings you're using yellow or clear lensed?
My experiances with yellow bulbs is a bad one, same buddy but with a different car had H1 clear lensed fog lights and after a month of use his bulbs burned out/melted the glass and failed cause they were yellow dipped...
Old Mar 31, 2009 | 10:07 PM
i have clear housings...i have OEM fogs with 3000K HID kit right now.
Old Apr 2, 2009 | 12:12 PM
skateboard_ej8's Avatar
im hench irl
They work great and allow you to see further up the road. You wont blind people either if you leave the glare shield on and aim them properly.
I had 3000k hid's in my ej7's foglights for over a year and never had any problems with them.
Old Apr 3, 2009 | 02:45 PM
ch0baca's Avatar
what's better?
yellow lens with 3000k HID or...
clear lens with 3000k HID or...
yellow lens with white HID...
which one provides better output / style
Old Apr 3, 2009 | 03:53 PM
Yellow with 3k yields a very bright yellow/amber and is very useable in bad weather (been in my buddies truck in a white out blizzard with them. Clear with 3k will be more of a pure yellow depending on the bulb (either it's dipped tinted or chemically modified), I've not used/seen yellow with 4300-5000k but I'm betting it'd be more yellow/ light amber depending again on the bulb and the color of the lens.
Clear with 3k will be the best if you want the yellow output but not the yellow lens, I personally went with yellow lens for the reason that it's cheaper to buy regular h3's than buy more expensive tinted h3's but I've yet to put a pnp kit into mine...
JforJonathan
Mar 13, 2004 01:10 PM
geminis2k
Nov 4, 2003 12:02 PM
LuckyNuts
Oct 20, 2003 01:27 PM
Greyout
Sep 23, 2003 10:03 AM
TurboIntegra
Aug 2, 2002 03:45 AM
