how do i replace my window?
OK i know how to take the door panel off. but from there its just a big sheet of steel blocking access to the passenger side window.
its horribly off tilt and driving on the highway is annoying with it.
From: I told you to wait in the truck in Texas, United States
To start with,
You will have to pull the plastic
vapor barrier out of the way..
Try not to rip or tear it..
Once inside,you will probably find that the window has detached
itself from the plastic mounting tabs which hold it in place..
"Window weld" or two part epoxy will usually work to refasten..
B16_4ME
May 26, 2009 06:47 AM
