Hot idle issue - Hondata S300
Old Mar 31, 2009 | 06:29 AM
champLSinteg's Avatar
Default Hot idle issue - Hondata S300
I just installed a new set of ID 1000cc injectors. I have gotten them to start and idle great at high 14s low 15s AFR when the engine is cold. If I try to restart the engine after it has already come up to temperature it will have a very low surging idle between 300rpm and 800rpm and the wideband has the AFRs at high 18s and higher. After a minute or so it will slowly start to catch idle and settle down. What should I be looking at?
Old Mar 31, 2009 | 06:57 AM
mtber's Avatar
Default Re: Hot idle issue - Hondata S300
Try playing with your fuel versus temperature compensation tables.
Old Mar 31, 2009 | 07:20 AM
Thanks for the response!
I am assuing you are referring to water temperature? Water temp correction setting at low engine load are...168*/4% - 177*/0% - 302*/0%. Should I increase the last two to about 5%?
Ldo
Engine Management and Tuning
Feb 20, 2011 05:39 AM
B20EF
Apr 21, 2009 10:51 AM
KILLAB17VTEC
Mar 31, 2008 02:36 PM
88da3
Nov 17, 2005 07:34 PM
*Boostwerks*
Jun 6, 2005 01:39 PM
