b20
Old Mar 31, 2009 | 05:22 AM
jesusjdm69's Avatar
Default b20
Will a b20 throttle work on a Ls motor and Ls mani???
Old Mar 31, 2009 | 05:32 AM
BokudenNYC's Avatar
Default Re: b20
" The B20 throttle body can work if you do one of 2 things:
1. Switch the throttle plate spring and throttle cable mounting bracket with that from an LS throttle body, so that the throttle cable pulls towards the driver’s side. You will also need a ’96-00 Integra LS throttle cable bracket if one is not already included on the manifold.
2. Use the B20 throttle cable bracket and re-route the throttle cable so that it pulls towards the passenger side. "
byc_cb7
Apr 3, 2012 09:08 AM
2fastss
Aug 7, 2009 11:44 PM
djmatix
May 19, 2007 02:00 PM
b20guy
Aug 18, 2002 04:34 PM
