wont start been in storage help
Old Mar 31, 2009 | 04:58 AM
Jcon8's Avatar
Icon3 wont start been in storage help
Okay so this may sound like a dumb question but I need your advice ht car has been stored for about 4 months with the occasional rough start I'm pulling it out of storeage and its giving trying to turn on but no go. The spark plugs need to be changed so I am hopeing that will do it any advice on what else I can try I tried tapping the starter but wouldn't budge. It use to backfire on the rough starts the past few months. Help what do you think?
Old Mar 31, 2009 | 05:01 AM
Tegraracer90's Avatar
Default Re: wont start been in storage help
so it doesnt crank over?....do u hear a clicking noise when u turn the key?
Old Mar 31, 2009 | 05:06 AM
Jcon8's Avatar
No it cranks over it just won't turn over
Old Mar 31, 2009 | 05:07 AM
GhostAccord's Avatar
1. Test your battery
Then once you know that the battery is good you can trouble shoot the rough start.
2. Check your timing to make sure everything is lined up.... timing belt/distributor
3. Check for fuel and fire (spark @ all 4 plugs)
4. How old is the gas in the gas tank?
Old Mar 31, 2009 | 05:10 AM
Jcon8's Avatar
Gas is a few months old I put fuel stabalizer in it tho should I get a few gallons of fresh gas?
Old Mar 31, 2009 | 05:26 AM
OK so your fuel should be OK. How is the battery?
Old Mar 31, 2009 | 05:39 AM
Jcon8's Avatar
Ygr battery has been charging the whole time wile its been cranking over but no start I hope to god its the spark plugs
Old Mar 31, 2009 | 05:44 AM
check to see if inside the distributor is corroded and check the rotor for corrosion
Old Mar 31, 2009 | 05:55 AM
x2
After you check that if there is nothing noticeable there pull your plugs and check for spark. Pull a plug and leave it connected to the plug wire. Ground the spark plug against the engine block, head, PS bracket, or valve cover and while the engine is trying to start watch for spark. If there is no spark you then know where to start testing ignition parts.
Don't go out buying parts and throwing them at the problem.....test them first.
Ignitor (ICU)
Ignition coil
Plugs
Wires
Cap
Rotor
JCritt
25
Apr 27, 2008 11:59 AM
eg686
Jun 10, 2006 12:58 AM
mrx381
Feb 14, 2005 10:16 AM
rainmanef
Jan 11, 2005 08:07 PM
junya16
Mar 1, 2003 05:41 PM
