Some curiousity questions about misfires.
Old Mar 30, 2009 | 11:17 PM
Hanmin's Avatar
Default Some curiousity questions about misfires.
Will a car misfire if it doesn't get adequate amount of charge?
For instance if the battery was bad, would that effect the spark? even enough to cause it to misfire?
Or if the alternator was bad, would it effect the power of the spark? again, enough to cause it to misfire?
Just some questions I never got around to asking my teacher, and it's spring break=].
Old Mar 30, 2009 | 11:28 PM
newtron63h's Avatar
Default Re: Some curiousity questions about misfires.
hmmmmmmm........................i guess its possible but i think a more likely scenario would be that the entire system would stop operating because of low voltage as opposed to JUST the spark not working.
what kinda classes you taking?
Old Mar 31, 2009 | 12:33 AM
ddd4114's Avatar
The battery would affect starts, and the alternator will affect spark power while the engine is running. If the coil stores less energy (due to a faulty alternator, ignition coil, etc.), then yes, misfires are more likely. This also depends on the resistance of rest of the ignition system and mixture density between the plug electrode and ground strap.
Old Mar 31, 2009 | 07:11 AM
newtron63h's Avatar
i agree but, this would only be happening for a very short time, because the engine would quit very soon after the misfires started from lack of power
driter
Jun 12, 2008 04:40 PM
ej1vtec
Jun 8, 2006 02:24 AM
B18ceed
Mar 18, 2006 04:41 PM
400whp
Mar 23, 2004 07:26 PM
