CRX EFI main relay....
Well what I am trying to ask is, will a 95 civic 4 door EFI main relay work in a 90 CRX SI. trying to find out have an extra one laying around, and wanted to find out before i plug it in, and try to start the car and blow something, or burn something on the car.
MIKE
MIKE
i used one once but you have to use the plug from the donor car, because it is different from the 88-91 one. what i did was de-pin the old plug and put the wires in the new plug in the same order, it never failed on me. ever. i recommend this to any EFer
i re soldered my main relay in my ef and it took me all of 5 minutes and it hasnt let me down since!
theres a write up somewhere maybe on here, and i know you can google it
so is it pretty straight forward all the colors match up, or you need a wiring diagram?
MIKE
MIKE
If the plug is the same (Theres center and offset) it will work. All the main relays are pretty much the same inside.
Or rewire it if you feel like you have no other option.
the plugs are not the same, but they use the same wires, so just match up the wires between plugs when you change them out and you will be good to go. when you look at them side by side it makes sense.
or basically in anything because its the heat and vibration that causes the connections to break on the PCB.
so i guess its an all around problem lol
91ef-si
May 4, 2019 09:15 AM
Juan_Mitosis
May 19, 2009 08:54 PM
