V-Band flange prices
Old Mar 30, 2009 | 07:29 PM
Sobe_Death's Avatar
Default V-Band flange prices
I'm looking around at v-band flanges/clamps and I've noticed something weird with the prices. The Vibrant flanges are about twice as expensive as most of the other stainless flanges I have found out there. What is so special about these that they are so much more expensive? Is it just the alloy?
-Parker
Old Mar 31, 2009 | 09:29 PM
GTibunny16v's Avatar
Default Re: V-Band flange prices
Vibrant ones have a quick release design so you dont have to take the nut all the way off. They also have a nice machined lip so the flanges match up easily, no trying to line it up while dicking with the clamp.
Old Mar 31, 2009 | 09:53 PM
redboost10's Avatar
www.racepartssolutions.com best prices and they will mix and match flanges if you need to connect aluminum to steel. and these also have the machined lip that is described above.
Old Apr 1, 2009 | 08:05 PM
Agtronic's Avatar
Most Vibrant stuff is expensive. Their v-band flanges are nice, but they're not as beefy as the others on the market. I use them alot because I have an account with them, but you have to be careful with the torque you put on them. (Naturally). The quick disconnect lever sometimes pops open. I like to tack the pin to the quick release lever. The inner lip is a really nice feature, they don't leak like other v-bands.
Old Apr 6, 2009 | 05:02 PM
Top Speed's Avatar
I also tack the pin. i've had to many failures otherwise. other than that problem. vibrant vbands are good quality
Welding / Fabrication
17
May 7, 2012 03:58 PM
that-guy
Sep 14, 2011 09:30 AM
BeArDy
12
May 18, 2011 01:50 AM
slowhitEJ1
Aug 25, 2009 09:27 PM
aryiman98civic
Dec 28, 2006 07:26 PM
