Extension Plate For Turbo Manifold
Old Mar 30, 2009 | 02:17 PM
D16SohcVtec's Avatar
Default Extension Plate For Turbo Manifold
I've been reading about people using extension plates behind their turbo manifolds to give a little distance from the turbo and the block. Where can I get those plates?
Old Mar 30, 2009 | 02:32 PM
Bailhatch's Avatar
Default Re: Extension Plate For Turbo Manifold
I guess you mean a headflange. Just buy one from one of the vendors on here. It's kind of ghetto and not that cheap, but it can work.
Old Mar 30, 2009 | 06:21 PM
boostedcivicsir's Avatar
Mr. Badwrench
yup just get a manifold flange. you will need longer studs. i have done this before and worked well.
Old Mar 30, 2009 | 10:04 PM
Thanks for the response. You run a exhaust gasket, then you put the spacer on, then you run another gasket, and then you throw on your turbo manifold is that how its done?
Old Mar 31, 2009 | 03:08 AM
Mr. Badwrench
yes 2 gaskets.
head, gasket, spacer, gasket, turbo manifold
Old Mar 31, 2009 | 06:38 AM
Originally Posted by boostedcivicsir
yes 2 gaskets.
Thank you, makes upgrading the 15g a lot easier without taking too much off my block now.
mattwl
Honda Civic (2001 - 2005)
Oct 10, 2007 11:44 AM
FmXRider991
Oct 4, 2004 01:13 AM
sicivic12
May 4, 2004 03:51 PM
Hybrid
Apr 9, 2002 01:10 PM
