speedometer
Old Mar 30, 2009 | 10:35 AM
kitsume's Avatar
Default speedometer
on my 91 hatch the speedsensor (or whatever it is) is not working and my gauge always shows zero mph
i was wondering how much it will cost for the part, and how hard would it be to replace it.
this is o a STD hatch so it has no tac just the speed.
Old Mar 30, 2009 | 10:38 AM
89s1's Avatar
Default Re: speedometer
make sure the speedo cable is still seated well into the speed sensor. then make sure it's also well seated in the cluster.
THEN start looking for replacement parts.
It's an easy fix, 2 or 3 little 10 mm bolts IIRC.
Old Mar 30, 2009 | 10:40 AM
kitsume's Avatar
where does it hook?
ive never dealt with that kind of problem before.
if i can find it, i can fix it :D
thanks :D
Old Mar 30, 2009 | 10:42 AM
Canadian_EF's Avatar
get a hanes manual... or use the auto zone online one.
don't go just replacing parts that may not need to be replaced.... it is a waste of money!
Old Mar 30, 2009 | 10:44 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Pics and info here:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/crx-how-change-tranny-fluid-1325930/
Old Mar 31, 2009 | 08:24 PM
ef_hatch89's Avatar
take off the housing for you gaugue cluster and make sure that it is plugged in all the way into your speedo if it is the problem is at the tranny.
96honda_EK
Oct 19, 2009 05:50 PM
gwchndlr
Mar 20, 2007 03:20 PM
joethejoeman
Jan 18, 2007 04:50 PM
kory97
Dec 23, 2006 08:08 PM
brent_G
11
Nov 26, 2003 09:05 AM
