Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
17' aftermarket rims for Accord 2003 ???
Old Mar 30, 2009 | 06:52 AM
torontoboyo's Avatar
New User
Icon6 17' aftermarket rims for Accord 2003 ???
Got a pair of 17' rims with tires p205 r15 for my honda accord 2003...would they sit right and roll properly...I know 17' are ideal for civics but for accord I do not know...can someone give me a good suggestion, bolts on rims are universal.
Old Apr 4, 2009 | 08:39 AM
07AccordEx-L's Avatar
Default Re: 17' aftermarket rims for Accord 2003 ???
no. the tires are R15 meaning they will only fit on 15" wheels. If u try to put them on, it'll be a stiff ride from what i heard. I wouldn't do it for safety purposes. as long as the bolt pattern is 5x114.3 then ur fine.
Old Apr 4, 2009 | 11:41 PM
civic noob's Avatar
New User
r15 means meant for 15 inch wheels..even if you were able to somehow mount the tires, the tire surface that touches the road will be deformed and not make good contact with the road giving you worse handling and overall performance. get some real r17 tires.. id also recommend going with a wider 215 or 225 tire too to protect your rims from rash and give you a bigger footprint and more traction.
Old Apr 10, 2009 | 08:56 AM
slammedk24's Avatar
New User
if you get a 17 inch rim you should run a 235/50/17
Old Apr 11, 2009 | 09:51 AM
Carcrazy1
Guest
Posts: n/a
you can have fair idea about the wheels at the below add
http://www.hubcaphaven.com/accord_wheels.htm
Sesavk
Apr 28, 2014 08:15 PM
702accord
Wheels
Mar 13, 2012 06:13 AM
JDM Accord 510
Dec 3, 2006 06:13 PM
NuG
Jun 3, 2006 04:50 PM
