JDM ecu in US car, second o2 is EGT?
Old Mar 29, 2009 | 11:20 PM
racebum's Avatar
Default JDM ecu in US car, second o2 is EGT?
quick question on a p73-003 JDM ecu going in a 97 USDM harness. i know the ECU doesn't need the CFS or the vtec oil pressure, those basically are ignored from what i gather. what i can't find jack on is the secondary o2. should i just plug the secondary o2 hole in the exhaust or does this ecu need an exhaust gas temp wired in?
Old Mar 30, 2009 | 04:44 AM
98_gsrteg's Avatar
Default Re: JDM ecu in US car, second o2 is EGT?
I have a B18C (JDM-R) engine in my GSR using the p73-003 JDM ecu with no secondary oxygen sensor in my custom exhaust. I have yet to get an engine light on running like this for months so I would take that it doesn't look for it. Hope that helps.
Old Mar 30, 2009 | 06:57 AM
irev210's Avatar
No second O2 is used.
Think of it as an OBD1 ECU with an OBD2 connector, heh.
Old Mar 30, 2009 | 06:59 AM
FOC-US2K's Avatar
Yeah I had that also, it a cat overheat sensor, I had it connected and there is a light in the guage cluster. You dont need it at all. Just plug up the 2nd o2 sensor hole.
Old Mar 30, 2009 | 11:36 AM
racebum's Avatar
awesome, thanks guys
birdtc1
Feb 24, 2010 10:13 AM
dstring20
Jun 2, 2004 05:08 PM
SleepnCiViC
Feb 9, 2004 06:11 AM
NH88TSI
Feb 7, 2004 10:06 PM
FLIPboi
Sep 12, 2002 10:22 AM
