Timing Belt issue
I changed my belts[ timing belt, balancer shaft belt and accessory belts too] I've driven the car for a few days already. The question is, the belts are making a Humming noise. Nothin loud, like if I had a loose belt or anything extreme like that. Just a Humm. I re-checked my belts and they are tight. Maybe someone can give some feed back on this matter. I do appreciate it.
You didn't say what year or trim level you had... but on some accords, especially 98-02 belt noise is normal. on older models and non-VTEC, excessive belt noise usually indicates over-tightening.
what's that mean... the weakest one?
maybe has the lowest output numbers but most of it is identical to the other F23 accords. it's just been de-tuned to run clean.
jsqu03
Jul 11, 2014 01:37 PM
BOOSTEDgreeneg
May 25, 2005 12:51 AM
nerdish
Jul 17, 2001 11:22 PM
