Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
4/5 point harness installation in a DB7
Old Mar 29, 2009 | 07:46 PM
Stillo's Avatar
Icon2 4/5 point harness installation in a DB7
i need to know where i can mount my harness points safely/legally in my 4 door integra
i have roll bar pictured below, im not sure if sure if this will aid my question
thanks in advance for any input
Old Mar 29, 2009 | 08:04 PM
98SpecR's Avatar
Default Re: 4point harness installation in a DB7
Consulting the rule book of the sanction body you are going to be running in should be the first place you look.
This PDF (see page 15 on down) will provide some really good information on how to mount your harness correctly.
Old Mar 30, 2009 | 11:02 AM
Stillo's Avatar
Default Re: 4/5 point harness installation in a DB7
that really helped me decide where to mount the shoulder harnesses, im going to use wrap around on the roll bar
as for the lap belts? where is every1 else mounting theirs?
i read online that your supposed to mount them 2 the cage, and also i read that you are supposed to mount them 2-3 inches infront of the vertial position of the seat.
i searched the gingerman web site and i didnt find it helpfull at all
Old Mar 30, 2009 | 11:03 AM
Stillo's Avatar
they mentioned that its not wise to use the factory locations for lapbelt incase of a side impact
Old Mar 30, 2009 | 12:01 PM
DB2-R81's Avatar
25 Year Member
Go here and read http://www.schroth.com/installation-.../en/index.html
Old Mar 30, 2009 | 12:52 PM
Stinkycheezmonky's Avatar
Suspetise...
The stock inner belt location won't be possible, as the buckle is attached to the seat. Most people drill a hole in the "transmission tunnel" and mount there, back far enough so that the belt has to come forward to you. On the outer lapbelt, some people (myself included) use the lower stock location. Others drill a hole in the floor. The fifth point should be obvious: hole in the floor. Just be careful not to drill through any brake or fuel lines, or into your exhaust.Note: I've never heard of someone mounting lapbelts to the cage, and I'm not sure how that would work exactly. Most lapbelts aren't long enough to reach the plane of the main hoop, even if you had a low bar there for them to attach to. They are also typically not the "wrap-around" style. Doesn't mean it isn't possible, but I've never seen it.
Old Mar 30, 2009 | 05:03 PM
Stillo's Avatar
thanks for that link
and thanks for the info on your setup. i was thinking of doing as mentioned above. i kept looking at different websites and didnt see any consistant installs
thanks again
egvtec
31
Jan 19, 2012 10:45 AM
slprrex
Jan 1, 2007 03:41 PM
8atman
Aug 2, 2006 07:41 PM
cayman_hatch
Aug 22, 2005 09:04 PM
delslow94
Sep 18, 2002 05:08 PM
