Valve Cover
Well i recently got my 92 LS project up and running. However, since I have a B1 block and a A1 valve cover i need to put a B1 valve cover back on.
now the question is, what color should i make it? I've painted it the same color as the A1 cover but it didn't flow with the design of the cover. Here's the current set-up. I need a color that really flows and works well with everthing.
My block doesn't have a PCV in it and neither does my valve cover. So i don't have a proper PCV system. Right now im using the fresh air vent and an in-line PCV valve.
