WTB: Auto to stick convertion
best bet is to pm a couple of the guys on here who are parting out si the auction cars, i know you will need the clutch and brake pedal assemblies, clutch master, resevoir, firewall line, clutch flex line, trans mounted line, and slave cylinder. if you want the clutch switch to work you can either run the wires to where they would go or you can grab a 5 speed dash harness. if yours is a 99-00 the si harness will work fine.
