where is the clutch fluid bleeding valve for 2000 Accord
I have Haynes repair manual for Accord 1998 and 1999. Mine is a 2000 Accord 5 speed manual transmission. The manual shows the clutch fluid bleeding valve can be found under the car in front of the transaxle. I can't really find it. BTW, what is the size for the plastic hose to fit to the bleeding valve. Can any body help? Thanks.
the bleeder is on the front most part of the transmission. should be facing the radiator fan. a vacuum hose works well for the job.
it's located on the slave cylinder which is mounted on the front of the transmission...
part #5 is the slave cylinder and part #6 in the bleed screw
benfromthebay
Oct 9, 2016 07:26 AM
amorak
Aug 28, 2006 06:19 PM
technine
Acura TL, RL & ZDX
Sep 14, 2002 01:44 PM
