Made 211whp 142ft/lbs tq...ideas to make more!
Old Mar 29, 2009 | 06:36 PM
scbmx87's Avatar
Default Made 211whp 142ft/lbs tq...ideas to make more!
Hey everyone, my current setup made 211whp and 142ft/lbs tq. I want to rebuild it this winter and shoot for 230whp on pump gas.
Its in a 2000 Acura Integra GSR.
The setup is as follows:
81mm ITR block
Stock ITR crank
Eagle big bolt rods
Wiseco 11.5:1 pistons
Fully ported GSR head
Omni Power flat face valves
Omni Power valve springs and retainers
Buddy Club Stage 4 cams and cam gears.
Skunk 2 Pro 2 manifold port matched to the head
Edelbrock 65mm throttle body port matched
3" intake w/ AEM filter
Edelbrock fuel rail
440 injectors
Aeromotive FPR
ACT 12lb flywheel
ACT street disc
B16 tranny
I plan on boring the block to 82mm and getting new Wiseco pistons, possibly Skunk 2 Pro 2 cams. Not really sure what else to do, shoot me ideas! Thanks in advance.
Old Mar 29, 2009 | 06:43 PM
UncleD's Avatar
Default Re: Made 211whp 142ft/lbs tq...ideas to make more!
Do you want to make more power or be quicker?
Old Mar 29, 2009 | 06:56 PM
KillaSIPP's Avatar
Theres no replacement for displacement... haha
Old Mar 29, 2009 | 06:57 PM
mar778c's Avatar
Community Builder
Community Influencer
You've got a pretty good motor now. Everything I could think of is going to be very very expensive like Carrillo Pro As, Accralite pistons, Castillo's re-work of your crank, RLZ head job, Pro3/M24s, Custom header, ITBS, TI valves, custom valve springs, etc.
Seriously, enjoy what you have.
Old Mar 29, 2009 | 07:04 PM
SOHCinWA's Avatar
Sounds pretty good to me too... Any street N/A car should be happy.
Old Mar 29, 2009 | 07:13 PM
scbmx87's Avatar
LOL, you guys are talking me outta rebuilding it this winter...How quick do you think this setup could go on slicks? I'm hoping for 12.90s or so. Possible?
Old Mar 29, 2009 | 07:17 PM
SOHCinWA's Avatar
200whp, with good driver, right suspension setup, LSD, should = high 12.90's in a street DC
Old Mar 29, 2009 | 07:37 PM
riceburner700's Avatar
could sleeve the motor and punch it out to a 84mm
Old Mar 29, 2009 | 07:39 PM
turbociv910's Avatar
x2 ^
hai_tech's Avatar
low 12 in crx
Old Mar 29, 2009 | 07:47 PM
Teamdiesel's Avatar
Do you have a graph? Not doubting you , just would like to see it
Old Mar 29, 2009 | 07:52 PM
BMo Tuning's Avatar
STAR
I already told you what to do, you son of a bitch.
Old Mar 29, 2009 | 09:02 PM
tealchief's Avatar
build the tranny, LSD final drive, shorter gears. or just get a type-r tranny.
Old Mar 29, 2009 | 10:22 PM
scbmx87's Avatar
I do have one...i'll see if my POS scanner will work for me tomorrow.
Old Mar 30, 2009 | 08:43 AM
hmoobhero's Avatar
lsd, valve job, and a good header/exhaust setup will get you more power. didnt tell us what kind of header you are running?
Old Mar 30, 2009 | 08:54 AM
FST GSR 1's Avatar
Now spray it and run 10.90's Problem solved
Old Mar 30, 2009 | 08:58 AM
FST GSR 1's Avatar
LOL, not at or near stock weight and balance it won't, but this thread shouldn't turn into a bench race!
Old Mar 30, 2009 | 09:24 AM
Ls_dx's Avatar
that thing sounds like a beast... LSD would be your fave mod ever tho!
Old Mar 30, 2009 | 09:45 AM
00MRSi's Avatar
LOL. Nice numbers.. Enjoy her
Old Mar 30, 2009 | 10:07 AM
scbmx87's Avatar
Maybe i should just get a better header and 3" exhaust. I have a hytech knockoff now and an Apexi N1 catback.
Old Mar 30, 2009 | 10:23 AM
mar778c's Avatar
Community Builder
Another good ideal.
Old Mar 30, 2009 | 10:55 AM
Do-Work's Avatar
i see you want to go with the Skunk 2 Pro 2 cams whats wrong with the ones you are using the>> buddy club4's
Old Mar 30, 2009 | 12:19 PM
logg_frogg's Avatar
Werd.
The cheapest way to get more power would def be to go for somore more displacement.
A used 89mm (B20) crank /w some custom pistons that have a higher wrist pin height would probably be the best bang for your buck with the least amount of work on your setup and would probably get you the 15 hp you are looking for
Old Mar 30, 2009 | 01:04 PM
tofu-eg's Avatar
nice number..for a 1.8 build..I'll be happy with it..I'm still hoping my 2.0 will hit that kind of number next week...hahaha
Old Mar 30, 2009 | 04:47 PM
Whats Up DOHC's Avatar
Damn those are strong numbers for a little 1.8L
