'94-01 Integra v. '99-00 Civic SI Control Arms for Sway Bar Install?
Old Mar 29, 2009 | 02:49 PM
oroca's Avatar
Default '94-01 Integra v. '99-00 Civic SI Control Arms for Sway Bar Install?
Hi,
I have a set of salvaged lower control arms plus sway bar from a 94 Integra. I am planning on installing the sway bar on my '00 EJ8, and I was wondering whether anyone has any opinions regarding the Integra control arms. My EJ8 seems to already have the SI control arms with a hole in them for mounting the sway bar, so all I need to do is use the same bolt plus an M10 nut.
The Integra control arms are heavier and have a threaded hole built into them already.
I'm guessing the Integra arms provide a better mount for the sway bar with the cost of some added weight. Anyone know if the difference is noticeable/ worth it?
TIA for any tips
Old Mar 29, 2009 | 02:52 PM
JasonYo's Avatar
Default Re: '94-01 Integra v. '99-00 Civic SI Control Arms for Sway Bar Install?
The integra sway bar bolts right up to the 96-00 civic perfectly fine, just get the right endlinks. you don't really need to put the integra control arms on.
Old Mar 30, 2009 | 10:16 AM
oroca's Avatar
Thanks for the reply 'yo.
Here is a picture of the Teg end link
so just change that and it'll bolt right on? Keep stock control arms?
egferio94
Apr 23, 2013 04:20 PM
vshavoc
Northern California (Sales)
38
Jan 11, 2011 02:57 PM
lazyxmofo
Aug 13, 2009 01:12 PM
RippSpeed
Jun 25, 2009 03:04 PM
anothersickhatch
Mar 4, 2008 06:23 AM
