spring rate question
Old Aug 13, 2002 | 10:48 PM
Chris_'s Avatar
Default spring rate question
say I have a set of springs 450 lb and 350 lb
what set up should I use because I have seen it both ways
450 F 350 R
or
350 F 450 R
what is the right way?
for a crx with b16
Old Aug 14, 2002 | 02:30 AM
jc836's Avatar
Default Re: spring rate question (crxconnection)
According to my expert you want the stiffer springs in the rear IF you have had any serious experience racing the car on the track. If this is a daily driver and you have little track time go with the higher rate up front-you can generally reverse them if they are the same height and diameter like Skunk2 or Ground Control Eibachs.
Old Aug 14, 2002 | 06:13 AM
Mr Furball's Avatar
Default Re: spring rate question (jc836)
you want the stiffer springs in the rear IF you have had any serious experience racing the car on the track. If this is a daily driver go with the higher rate up front
I seconed this, I have a crx with B16 and I am running 400 back and 300 front
This is a little bumpy but not bad
skunk 2 coil overs and tokico blues
Old Aug 14, 2002 | 01:19 PM
Chris_'s Avatar
Default Re: spring rate question (FURBALL B-16)
I only ask because I was looking at the spring rates for Tein and all of their coilovers are higher spring rate in the front and lower in the back
Old Aug 14, 2002 | 02:13 PM
HybridFiend's Avatar
Go with the higher spring rate in the front, that is where the majority of the wieght distribution is. If you want a drag car, and only a drag car then go with the higher spring rate in the rear. That will give you more traction on your launch. I have skunk2 coilovers with 450lb front/350lb rear and using KYB AGX 4-way adjustables. I have the dampening set on 2 front/rear for street and 3 front/rear at the track. That is the key for best turn-in cornering/fast cornering without loosing traction. The job of the spring is to support the sprung weight of the vehicle, so put the higher spring rate where the weight is.
Old Aug 14, 2002 | 02:18 PM
Steve91's Avatar
How do you use the car? For a street car, the 450F/350R will give a smoother ride and safer(understeer) handling characteristics. If you plan on autocrossing the car, then you want the 450's in the rear to help the car rotate.
Old Aug 14, 2002 | 03:29 PM
performula's Avatar
Default Re: spring rate question (HybridFiend)
Let me ask this question...
I ordered Koni Sports (yellow) and the rear shocks are so much larger than the fronts. It seems odd that the rears are larger than the fronts due to weight. Why is this? Passengers and weight movement?
raverx3m
Suspension & Brakes
Mar 30, 2016 04:25 PM
DawgC2
Suspension & Brakes
Dec 23, 2011 10:04 AM
jdmhatch1
Suspension & Brakes
17
Feb 27, 2009 06:54 AM
96-EJ6 B18C
15
May 18, 2004 07:48 PM
