pro's and con's for hondata ecu
Old Mar 29, 2009 | 11:33 AM
cryoman999's Avatar
Default pro's and con's for hondata ecu
any have info on the hondata ecu - I am going to run full race b16 turbo and want to make above 500hp.
Old Mar 29, 2009 | 12:20 PM
Davidls's Avatar
Default Re: pro's and con's for hondata ecu
use hondata s300
Old Mar 29, 2009 | 12:47 PM
leroyb's Avatar
wats the differences between s200 and s300
Old Mar 29, 2009 | 02:36 PM
boostedcivicsir's Avatar
Mr. Badwrench
300>200
s200= chips and a burner
s300= no chips and more cool stuff.
Old Mar 29, 2009 | 04:30 PM
Garage 808 Hatch's Avatar
the only con i see with the S300 is no way to control more than 4 injectors, but since you're only aiming for 500ish, it will be perfectly fine
Old Mar 29, 2009 | 07:38 PM
V-SPEC 1's Avatar
hopefully hondata step up to the plate and maybe they can get the s300 to work w/ 8 injectors.
Old Mar 29, 2009 | 08:04 PM
civicsi940's Avatar
i think hondata s300 are still going for cheap due to their move.
Old Mar 29, 2009 | 08:11 PM
Davidls's Avatar
s300 out weighs the s200 by a lot. if you go e85 and have the s200 your car most likely wont start when its cold. s300 has boost by gear and many more options. i believe s300 is only running for $600
Old Mar 29, 2009 | 09:12 PM
omiehomie's Avatar
link please because i have been looking with no luck
Old Mar 29, 2009 | 10:14 PM
bunnyx's Avatar
you can find s300 set-ups on eGay.
Old Mar 29, 2009 | 10:26 PM
damndan23's Avatar
logicmotorsports.com i bought one from them about a month ago s300 w/boost installed in a p28 for $820.00 shipped....
ive also looked on e-bay and the prices are quite a bit higher, unless u can bid on a used s300. LOGIC has the best prices i have seen yet .. i think phearable.net has them at a decent price also!!!
GL!!
Old Apr 11, 2009 | 04:54 AM
Got_EF8's Avatar
call this guys up eugene http://www.prostreetimport.com/ thats his web link to the shop. i think hes one of the best tuners out there that money could buy aka affordable
Old Apr 11, 2009 | 05:26 AM
jdm kidd's Avatar
well its been proven u can run 8 injectors but only ina parallel.......however u cant stage them
Old Apr 11, 2009 | 08:52 AM
locash's Avatar
You can stage them too, it just takes a bit more work..
Old Apr 11, 2009 | 09:02 AM
DaveF's Avatar
does s300 stilll have the ECT/ timing issue ? or did they fix that ?
Old Apr 11, 2009 | 11:41 AM
boarding2008's Avatar
Phearable.net has s300 for 590 I believe
Old Apr 11, 2009 | 11:50 AM
mtber's Avatar
Hondata s300 would be the ideal solution for your application.
Feel free to contact us if you have any questions concerning the system or it's features.
Old Apr 11, 2009 | 01:41 PM
marcj's Avatar
go with eCtune
Old Apr 11, 2009 | 07:24 PM
turbo sol's Avatar
i have s100 what is the ECT / timing issue? is this something i should be aware of?
Old Apr 11, 2009 | 07:45 PM
1320Mikey's Avatar
s300 is great. There really are not any cons, you pay $550 for a system that is GREAT. The s300 is so much better in so many ways over the ectune/neptune systems for one reason its usb live update.
Old Apr 11, 2009 | 08:45 PM
j-bird20's Avatar
I can do the same thing with ectune with the ostrich. If you really want. Take the ostrich apart and put it inside the ecu. THe only difference with ectune is ull have 2 usb's unlike hondata 1. I can load and change anything i want, whenever i want, anywhere i am.
Old Apr 11, 2009 | 08:49 PM
TurBo81's Avatar
sorry to steal your thread, but have hondata made a system for OBD2????
Old Apr 11, 2009 | 08:53 PM
mrbsponge's Avatar
the only thing abou the ECtune setup I dont lik eis if you are somewhere and your emulator takes a dump, or gets wet, or damaged or something of the sort, then you are basically out of luck till you get a new one as you cant burn that to a chip
Old Apr 11, 2009 | 08:54 PM
Blown90hatcH's Avatar
No.
Old Apr 11, 2009 | 08:57 PM
TurBo81's Avatar
Originally Posted by Blown90hatcH
No.
just wanted to make sure...one of my friend said they have...trying to prove a piont to him...thanks....Blown90hatcH....
