anyone know why my car sits uneven?
when I bought my car a 00 ek hatch the back drivers side had a blown shock which i guess caused the passenger side to be higher so recently I changed to tokico blue shocks tein s tech springs skunk2 lcas blox chamber kiT drove the car for about a whole day to wear everything in and the passenger side still sits higher by a finger the drivers side u can fit 2 fingers between wheels and fender the passenger can fit 3 fingers. Anyone know why this Is happening?
The drivers side quarter pannel next to the taillight has been bonddaled iono for what cars clean titled something happened might not been reported? Any other possibliltys?
I don't think this is it but... is the camber or caster way offset on one side? other then that maybe just bent s**t, frame torqued, ...really uneven tire pressure...?
your engine is heavier than the tranny and sits on the driver side which causes it to lean towards the driver side.your driver side spring must have saged a little.id just swap the left and right springs to even it out if it matter to you.
my 93 si sits w/ the passenger side higher. bought new eibach springs and koni struts... same lean. never saw an eg/ek coupe or sedan rollin with a gangster lean. clean title clean history. my 95 cx never did this tho. my si's stripped of a/c and p/s. drives me crazy looks like someone walking with one leg longer than the other
My sedan did this when I had lowering springs, after a while I noticed the driver side had a slight lean to it. It led me believe it was just the way the springs settled.
It will take longer than one day to break in the springs. Just give it some time n see what happens. If you have things in your car and trunk move everything over to the passenger side to compensate for your weight. Make sure you are parked on a flat surface also.
hawksftball2007
11
Feb 20, 2012 10:25 AM
