P2W clearance!
Hello,
I have a oem style ctr piston set, spec is .010 - .040. What do you normally set your p2w clearances at for street driven, weekend race car?
I'm in the process of building the motor and I want to have all my numbers correct before i give the motor to the machine shop.
ctr pistons 81.5mm
gsr crank/rods
b16 head
toda vtec killer 295's.
oem head gasket
ctr pistons 81.5mm
gsr crank/rods
b16 head
oem head gasket
Hello,
ctr pistons 81.5mm
gsr crank/rods
b16 head
oem head gasket
ctr pistons 81.5mm
gsr crank/rods
b16 head
oem head gasket
yes^
I have a Motec M400 ECU to accompany the cams.
Thanks for the reply, Any others? Just trying to see what other people have to say! Sucks there is not a machine shop around me that knows about honda engines.
Any competent auto machine shop can give you the specs your looking for with the bore size/p2w tolerance, even if they are more bias twoard domestics. I would be specific with them about the specs for the honing finish though as that is equally important.
vtecmonster001
15
Apr 10, 2007 08:10 PM
Addicted2Racing
Mar 17, 2006 10:52 AM
Ruby Civic
Dec 27, 2003 10:14 AM
