Removing headlight glue and silicone
I redid my retro-fit a few days ago, now since its been raining and my headlights has moisture in it. What is a good product to remove headlight glue and silicone? I try oops and that did not work. Would acetone work or should I just heat the glue and silicone out and try to remove it that way? I want to remove all the glue and start the resealing process over again.
^^i agree, i would try heating it up to get if off first. you could try using a dremel with a brass wire tip to get it off. thats what i used when i took apart my fog lights. it work very well actually.
thanks 98civdx and zsudz922, I guess their is no easy way to do it.
will try the heat gun again on tuesday.
i had same problem soo i went back with a heat gun like the first time was to lazy to go to the store and buy the silicone and learned the hard way when i seen em on a rainy day soo i redid em and put slilcone and bamm it could rain alll day and they still good hope this was helpfull enough
BlueIntegraBoy
Sep 7, 2008 05:34 PM
