what size injectors should i go with?
Old Mar 28, 2009 | 06:06 PM
jonnydbagz's Avatar
Default what size injectors should i go with?
im running all motor high compression d16y8, mid/high cam, str trottle body, skunk2 intake manifold, all other fuel components upgraded. oh and what pressure? thanks, jon
Old Mar 28, 2009 | 06:54 PM
formervendor's Avatar
Banned
Default Re: what size injectors should i go with?
270-310cc and typically 55-65psi
The injectors should come with a spec sheet and should also recommend a pressure.
Old Mar 29, 2009 | 07:51 AM
jonnydbagz's Avatar
do you know this just from experience or is there a way i figure it out?
Old Mar 29, 2009 | 08:05 AM
Lubo_25's Avatar
go to RC's website and take a look at the calculations there might be a little help...
Old Mar 29, 2009 | 11:08 AM
jdm_sir2's Avatar
Just run some prelude injectors should be fine. SOHC don't make enough HP to max out the injectors....
Old Mar 29, 2009 | 11:18 AM
DSRxCandyh2bEG's Avatar
310s should be more than enough. I would go with 97+ prelude injectors even...
i am running 370 cc injectors on my 2.3L h22... just for refference...
Old Mar 29, 2009 | 12:48 PM
jonnydbagz's Avatar
anyone got some for sale or know where to get em? thanks for the replies
Old Mar 29, 2009 | 01:44 PM
Chris Tune's Avatar
stock 240cc's... ull never run dry with those... ever...
dE.fUsEd
Nov 24, 2011 07:29 AM
mdj_ge
Jun 24, 2005 01:21 PM
chris@allmotor.net
12
Aug 21, 2003 03:30 PM
B_1_8_hatch
May 6, 2003 04:34 PM
