wtb: spindles and hubs for ef b series swap
my buddy is swapping an ls into his dx ef hatch and needs the hubs and spindles from i believe a da integra or a ef civic ex or si.
if i am wrong please correct me, i've never done an ef swap but this is what he says he needs anyways let me know what you've got.
u can use b series axels u would use in a eg u gotta pop off a dust ring it keeps the axel from poppin all the way in its kinda hard to explain but on the back of the hub were u insert axel their is this little ring arount the outside u just pop it off wit a flathead screwdriver and the axel will go in in worked for me on 2 cars so it should do the same for u
yeah my buddy said that the ones on the dx are smaller so you need to replace them, he did the swap once before and said he used the ones off the da integra front clip he had and it worked fine, but he said that the ex and si models have the same size hubs because they are 1.6l
Oct 17, 2008 12:27 AM
ProjectLSVTEG
Mar 21, 2007 08:45 AM
91tegrals
Jan 30, 2005 07:58 AM
