distributor rotor screw???
Old Mar 28, 2009 | 02:08 PM
miked123's Avatar
Default distributor rotor screw???
well heres the thing my cars been running like $hit so bad i got a cel. anyway i havent tuned it up since i bought it cause the guy i bought if from did it like 2 months before i bought it so i figured its bout that time so i get the parts take the cap off line up the screw on the rotor and go to take it off but its stripped i used every size phillips and flat head i had and no luck. any one got ideas? dont really want to spend the money on the bolt extractor kit but if i have to i have to.
Old Mar 28, 2009 | 03:59 PM
instructor74's Avatar
Default Re: distributor rotor screw???
here are a few tricks, first if the head is not to bad badly stripped and you can still get a philips to fit in dip the tip of the screw driver into valve grinding compound then insert into the screw. now insted of trying to twist the screw out press down on the screw and use several short hard snaps of the wrist to try an brake the screw loose. if that doesn't work you can try using a small set of cutters to bite into the side of the screw head and just like with the valve grinding compound snap your wrist hard see if that brakes it. I have never had these 2 ways fail me getting any screw out
Old Mar 28, 2009 | 06:33 PM
4doorekITR's Avatar
ive had this problem too...Heres what i did cuz mine was completly stripped. I had to use a cutting plier and basically just cut off the old rotor.It came apart in peices..Once i had it all removed i had just the stipped out screw threaded into the shaft, I just used a pair of vice grips locked onto the sides of the screw and twisted it out..Its not the most pretty way of doing it but it was my only choice at that moment..And of course it cost me a rotor..But there was no damage to the distributor shaft or anything else once i was done.
Old Mar 29, 2009 | 05:41 PM
MILF_HUNT3R's Avatar
i agree with 4door ek same problem break it off and use good ol pliers to take off the screw
Old Mar 31, 2009 | 02:45 PM
miked123's Avatar
ok sounds good i will give it a try. im not worried bout the rotor i have a new one anyway just dont want to break nething else
Old Mar 31, 2009 | 02:58 PM
EL Vap133's Avatar
How bad is it stripped? I used an impact screwdriver but very lightly and it worked.
Old Apr 2, 2009 | 04:02 PM
miked123's Avatar
its bad i cant even begin to turn the screwdriver before it slips out of the screw. i was actually sitting on top of my motor using all my weight and it still slipped out
aTrOcIoUs420
Mar 16, 2010 08:02 PM
mzahidi
May 2, 2007 10:18 AM
95_red_dc
Sep 24, 2006 02:35 PM
boosted k20
Jan 7, 2005 10:01 PM
Weston
May 3, 2002 08:16 PM
