IAB Vacuum hookup with broken nipple
Old Mar 28, 2009 | 12:58 PM
MikeLuder's Avatar
Default IAB Vacuum hookup with broken nipple
I broke a nipple on the backside of the intake mani while installing the motor and had to jb weld it closed. it's the line going to the IAB starter valve
All my vacuum lines on the intake mani are capped off except for map.. I was wondering if I could hook the IAB valve to a different nipple does it matter? or is the one I broke the one needed for the IAB to function properly
number #12 in the pic is JB welded and the rest are capped off.
or the nipple to #22
I searched on how to hook it up but can't find an answer if i'm screwed because this nipple is busted.
apparently ive been driving with them stuck open.
Old Mar 28, 2009 | 01:55 PM
Tizzakowack's Avatar
Default Re: IAB Vacuum hookup with broken nipple
uc an try it. have some one rev the engine up and u can tell if they are closing and opening.
Old Mar 29, 2009 | 12:37 AM
MikeLuder's Avatar
just trying to figure out if it really mattered if the exact nipple had to be used.. or if I should try to rig it with my intake pipe.. I've been reading about people hooking it up different ways but It's not correct, (opens at WOT instead of 4500)
ryanevansoh
15
Sep 2, 2009 09:55 AM
MilanoLude
Sep 24, 2007 03:19 PM
93sleeper
Mar 22, 2005 01:50 PM
Rice_Boy
Nov 21, 2001 06:53 AM
