Removal of the govenor ?
Im just wondering if any1 conqured this yet since majority of our si top end sucks and its mainly due to the 130hp govenor has any1 bypassed this or came out with a solution to removing this
Well you certainly are not hitting that at a circuit track and you're certainly not hitting it in a 1/4 mile. And speed limits in Cali are what? 65/75mph at most?
I think you're safe with a 130 mph governor.
im sure the k-pro you want to get will do that if you have enough power.. and ive gone over 130 with it stock the highest i got was 137 then the power just wasn't there. I should try and make a run with it now but it scares meat those speeds
Road House
I don't know if I believe there is a governor. I think it is just a lack of power.
Supposedly on my EM2 there was a 112mph governor, but I frequently hit 120mph+
the 2006 Si didn't have one and very early 2007's didn't either, at least the 07 Si Sedans. The govenor on the Si I had cut at 133, so did my brothers and we relied on GPS navigation, way more accurate than stock speedo.
There is a wide debate on whether or not the current or old Hondata reflash removed it but I'd ask Hondata and not rely on HT or 8th civic rumor mill for that.
06' Si are limited to 157mph
07+'s are limited to 133mph
Here is videos of the limiter:
07
http://www.youtube.com/watch?v=ffBtl0wYey4
06
http://www.youtube.com/watch?v=JFbn-4BW2Cw
07
06
I hit 134 in my stock 07 then i hit RPM cutout. If i had a higher RPM in 5th gear i could proly gone faster. Didnt go into 6th gear becuz i dont think the stock engine is powerful enuff to push that fast in 6th gear. But now that i have thout about it next time im on that same stretch of road i will try it and see what happens. I think on a supercharged or turboed civic you could go faster than 134 in 6th cuz youd have the extra power. I guess about that "06" Civic that hit 157 i cant tell if its stock. I dont think a stock civic does have that kinda power to push that far into 6th, SO if its not a stock civic it could have a piggybacked ECU to help tune it for that amount of extra power, or depending on the piggyback it could be limited by the other ECU not the stock SI ECU.
I guess i dont wana say theres not a governor but idk if that video is real proof.
Any charged civics on here that have gone into 6th and such?
I bought an 07 Si sedan just before thanksgiving in 2006 and I know for a fact that NOT ALL 07 Si's had the limiter as I had it up to 143 xmas eve 06 when the free way was baron. Unfortunately the financing on this car got rolled back and I had to turn it back in. It was a shock to me when I got an 07 Si Sedan June 07 and it was bouncing off 133.
I have gone on several top speed runs and the average is 130-131, there is a govenor cause the rpm's basically doesnt go anywhere past 5k once in 6th. The reason why i ask is due to the fact that a dc5 / dc5-r tranny does not have the speed govenor. Hopefully the k-pro that in the works can tackle this issue so si's can have a lil more top end to compete. I have seen some base si' keep up with wrx and evo on a roll through 4th but once 5th kicks top end is very sluggish
A transmission is not what "governs" your speed......it does eventually determine it due to gearing but it is not going "okay, well I can go up to 150, but you're going 130 so I"m going to stop you there"
The governor is software controlled, either speed or rpm limited hence why "reflashes" can remove them.
this man is correct.
and i agree wit wat someone said before. theres no reason for u to be goin that fast in the first place
Road House
^--- Downhill? =P
Wouldn't Canadian and American laws differ as to the nature of electronic-controlled top-speed?
Are M3s and other higher-powered cars limited to 133mph, as well? If not, why not?
...skeeter...
no. there's no law in place regarding speed governors, it's up to the manufacturer to put them in. honda might feel that the car isn't safe above 133 mph for whatever reason, or just to protect idiots from themselves. there ARE street cars that will do 200+ in the u.s.
All supercars german cars are limited to 155mph, m3, m5, s55, s65, sl 55-500, 600s. It's a joint agreement with all german automakers.
but it's not because of an american law. FigiBlueFG2 was asking if the speed governor was in place in the civic becaue of a law, and i said that no, it's not.
Both where done on dyno's where there is NO resistance, the 06 Si would not have been able to hit 157mph on the road,this cars feel like they just fall flat once you shift to 6th gear at a high mph on the road. We decided to see if there was a speed cut out since we were on the dyno, and thats where the video comes.
Yup right on, just saying there are some governors set in place by certain manufacturers for a while i.e. the germans.
