Quick question about Jun 3 cams and Brian Crower valvetrain
OK sorry if this is too noob of a question for some of you.
My setup:
B16B
stock bottom but i will run a thinner gasket to bump compression up to 11 or so.
I will be running Jun 3 cams and keeping the revs at 9500 or below.
Will the Brian Crower springs and retainer be ok?
Does anyone have any negative or positive experience with these springs/retainers?
If you need any other info let me know and thanks in advance.
My setup:
B16B
They should work, pretty sure those springs and retainers are made to work with all of the BC cams, some of which are probably bigger than those JUN 3s.
Looking at the BC website right now and both their valve spring retainer kits are compatible for their biggest cam profile. Go check the specs on those and find the specs of the JUNs to compare, if you really need to make sure get a hold of tech support at Brian Crower.
hmm compare cam specs.. have no idea why i didn't even think to do that. thanks man..
end thread
end thread
Personal experience. I ran Jun3's with Blox VS and Retainers, no problems reved to 9100 and made excellent power up to 8700. JDM ITR B18c Stock Block
hybridturtle
Jan 6, 2005 09:12 PM
se93
Oct 28, 2002 08:12 PM
