rear quarter rubbing my tire.
Old Mar 27, 2009 | 08:21 PM
iiPancho's Avatar
Default rear quarter rubbing my tire.
Ok, long sotry short, got in a wreck and my rear quarter on the passenger side is jacked up. this happened with snow tires on which were pretty skinny.
summers coming up, i put my rims on which have nitto neogens. not sure the side but there quite a bit wider.
anyways the peice of metal from the rear quarter kinda came untucked and now is scraping the tire.
i try pounding it back up into the wheel well but no luck.
this needs to be a quick fix because i just dont have the money to have the bodywork done and i need this to drive daily. and it doesnt matter how much more damage it does cause the quarter is gone anyways.
Thanks
Old Mar 28, 2009 | 05:18 AM
Mitsjiel's Avatar
Default Re: rear quarter rubbing my tire.
Set your suspension on a higher level?
Old Mar 28, 2009 | 06:46 AM
devney's Avatar
x2 on raising your car. The noob got you lol. I mean unless you're willing to do body work or raise your car, I'd say you either need to just live with it or put your snow tires back on till you can fix it.
Old Mar 28, 2009 | 07:30 AM
mymmeryloss's Avatar
take a pry bar and pry out the wheel well...
Old Mar 30, 2009 | 07:59 PM
burningrice4cyl's Avatar
I took a grinder with a cutting wheel and about every inch made a cut the took a rubber hammer and bent the tabs I cut in never had another problem
netopia
Apr 5, 2013 11:02 PM
sleekcesar
Jan 30, 2010 01:51 PM
Stykz
Oct 16, 2008 09:01 PM
govtec
Mar 7, 2005 06:48 AM
91integraLSVTEC
Feb 12, 2004 07:56 AM
