92 B18a1 obd1 r obd0
Old Mar 27, 2009 | 05:49 PM
tego_integra's Avatar
New User
Icon2 92 B18a1 obd1 r obd0
if im correct from 1990-91 was used obd0 then in 92 the used obd1...i have a 92 motor so i think on my 90 integra but im using the old dizzy obd0 would it still work or not ... i would turn my car on and about 3g it would start to lag ... then my check ingen light came on and i wouls give it gas but it would not go the rpms would drop not i try to turn it on it starts but 2 sec later dies...and my ecu is giving me code #4 .. what should i do
thanks
[[tego]]
Old Mar 27, 2009 | 07:25 PM
mrchevez's Avatar
Default Re: 92 B18a1 obd1 r obd0
thanks
[[tego]]
Reminds me of me right now. Im in the same situation as you, ill like to talk to you more so you can help me out on some stuff because im doing the same thing as you but yeah
90-91 is OBD0 and 92 is OBD1.
Can you say what you mean again bcus i do understand but than i dont
Old Mar 27, 2009 | 07:37 PM
darkstarsinner's Avatar
Your O2 sensors are different per the ECU, which is why you are having the issues. You need an OBD0 to OBD1 harness. Check out Rywire.com dude has an awesome product for a decent price. You also need the OBD1 ECU from the 92-93 Integra. Or just a PR4 will work.
http://rywire.com/store/obd0-obd1-co...9ec4d62060f7d0
Old Mar 28, 2009 | 07:50 AM
New User
i have a 90 integra obd0 with obd0 ecu but i have done my swap to obd1 motor the 92
B18a1 after a month the check engin light came on and now my car wont stay on and my obd0 ecu is trowing me code #4 ...im thinking about getting the p30
Old Mar 28, 2009 | 08:41 AM
if it was fine for a month you may be having other issues. There is more to it then what you have done, and just buying the OBD1 harness isn't going to fix your problem. You need a converiosn harness, and a few other pieces to go with it. Join G2IC and ask around on there. It is all G2 Integras.
Old Mar 28, 2009 | 08:47 AM
New User
ok thanks email me if u got more info ... guerrac_JDM@hotmail.com
Old Mar 28, 2009 | 11:31 AM
Just hbit up www.g2ic.com Plenty of people here have done the swap so you will have all the info you need in one thread.
IHEARTMYHONDA91
Oct 20, 2009 12:13 PM
schmiddr2
Apr 2, 2008 05:37 PM
nWilk666
Apr 12, 2007 04:38 PM
12SecHatch
Aug 17, 2004 10:18 AM
Hondasaurs
Mar 21, 2003 12:03 AM
