Civic Type R Fuel Pump question
Old Mar 27, 2009 | 04:06 PM
GTlvr82's Avatar
Default Civic Type R Fuel Pump question
1. I'm installing a CTR engine soon
2. Engine is not in my possession yet
3. My current fuel pump is bad (using a D16y7 engine)
4 *QUESTION*: can I use the CTR pump with the y7 until I install the CTR?
Thanks...figured I'd make it as simple as possible.
Old Mar 27, 2009 | 04:07 PM
90Rexx's Avatar
Default Re: Civic Type R Fuel Pump question
of course you can. a fuel pump is a fuel pump. they are all the same. just different shapes. im not 100% but i believe all 96-00 civic fuel pumps are identical.
Old Mar 27, 2009 | 04:09 PM
GTlvr82's Avatar
The fuel rate is higher on the CTR pump...I didn't know if that would cause overpressure...hence the question.
Old Mar 29, 2009 | 10:44 PM
blk_eg4's Avatar
the rate might be higher on the pump but the regulator is the one controlling the pressure..i believe
Old Mar 29, 2009 | 11:03 PM
Davus's Avatar
I've used the Holley Walbro 255 LPH (67 gallons per hour I believe) pump on a stock D16Y8 for near two years. I threw a rod, but it was unrelated.
thunderboy
Jun 20, 2011 03:52 PM
confyused
Apr 6, 2005 03:31 AM
