Valve Cover Bolt and Threads in Head
I was an idiot and overtightened one of my valve cover bolts. It snugs down but not to torque spec and it is causing a slight valve cover gasket leak. The bolts seems ok but I will likely get a new one. My question is, What is the best way to repair the threads in the aluminum head. time-sert? helicoil?
You might be able to get away with just using a slightly longer bolt, as the thread in the cylinder head usually goes a little deeper than the length of an OEM bolt.
gnarlycs
Jan 13, 2013 02:46 PM
Nathan007
Nov 25, 2008 07:17 AM
wilsel
Dec 26, 2003 08:41 AM
