really bad idle? white smoke from exhaust.
Old Mar 27, 2009 | 03:03 PM
tony7626's Avatar
Default really bad idle? white smoke from exhaust.
my car overheated yesterday, i didnt notice the temp till it was smoking and all my coolant leaked out. i was nowhere home so i had to drive it and then turn it off and wait and drive again. took me forever to get home. this morning i have white smoke coming out of the exhaust. i already filled my reservoir back up with coolant. my idle is stuck at 2500 and it goes from that down to 1k and back up over and over again. i know white smoke usually means a head gasket, but would that cause my bad idle?
Old Mar 27, 2009 | 03:25 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: really bad idle? white smoke from exhaust.
It the head gasket alright...you have coolent going into your engine and causing both bad idle and white smoke as it gets burned. Don't run it like that for long, it will ruin your rings
4drEF's Avatar
Keyboard Humorist
Sensors freaking out from the leaking headgasket.
Old Mar 27, 2009 | 08:18 PM
EF9Lowlife's Avatar
change you head gasket then buy about 3 times worth of oil for 3 oil changes. I had same prb before when i did a z6 swap in my crx the intake gasket was bad..anyway warm oil up and let it drain out so you get all of that milk brown out good enough then give her a clean oil change and you should be good.
Old Mar 27, 2009 | 08:43 PM
Brujo13's Avatar
you should fill the radiator up, not jus tthe reservoir, speacially if the coolant got burned/leaked out
def sounds like a head gasket prob
Old Mar 27, 2009 | 10:48 PM
single v t's Avatar
it is all because of your head gasket get that fixed asap
TheFamilySign
35
Mar 3, 2014 12:12 PM
91b18a1ls
Aug 26, 2012 12:46 AM
Spooon
May 23, 2012 08:47 AM
bpfergu
Mar 5, 2012 05:27 PM
gunterelectric226
Dec 3, 2008 06:49 PM
