Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Help me program Key fob remote!!!!
Old Mar 27, 2009 | 11:05 AM
lsvtechatch92's Avatar
Default Help me program Key fob remote!!!!
Ok i bought a remote off ebay how do i program it to the car??? its a 04 accord
Old Mar 27, 2009 | 11:18 AM
mikesrex's Avatar
Default Re: Help me program Key fob remote!!!!
a local honda dealership should be able to help you out
Old Apr 1, 2009 | 04:45 PM
danec's Avatar
New User
Programming for 2002 to 2004 Honda Odyssey
When
Remote transmitter added or replaced.
System malfunction.
How
Obtain all remote transmitters.
NOTE: A maximum of 3 remote transmitters can be programmed.
Switch ignition ON.
Proceed as follows:
NOTE: Point remote transmitter at central locking signal control module
(located behind glovebox).
Switch ignition ON. ( Just before actually starting car ) Proceed as follows:
Within 4 seconds: Press LOCK button of first remote transmitter.
Within 4 seconds: Switch ignition OFF.
Within 4 seconds: Switch ignition ON.
The Locks should now cycle. This indicates the car is now in the programming mode
and activated to accept the programming of the remotes.
Within 10 seconds:
Press LOCK button or UNLOCK button of first remote
transmitter, allowing doors to lock and unlock once.
Press LOCK button or UNLOCK button of each remaining remote
transmitter to be programmed, allowing doors to lock and unlock once as
each remote transmitter is programmed.
Remove key.
Check operation of all programmed remote transmitters.
Old Apr 1, 2009 | 10:08 PM
cobra94563's Avatar
New User
I have an '05 honda. If you have similar key, you can program the remote lock functions with instruction available on the internet.
If your key has an immobilizer chip , the dealer will have to program the ignition to accept that key. I assume you have to have it cut as well.?
Old Apr 6, 2009 | 10:13 AM
PlayForFun's Avatar
take it to the dealer, I just did this with my 08,
go to the service department, some of them will charge other wont depends on the dealer, the thing is there going to charge you whether the key works or not. it is doubtful that they will only cut and program the immobilizer for you unless there friends of yours.
when you go in take all the keys for your car with you, when they program the door locks only the keys present are going to work.
if you can get the key cut and the immobilizer done then follow the steps posted above to program the door lock controls.
feel free to pm me if you have other questions.
~Play~
Steve LeClere
Honda CR-V & Element
Jul 21, 2012 12:17 AM
zx3focus
Acura TL, RL & ZDX
Dec 1, 2008 05:52 PM
technine
Audio / Security / Video
Sep 7, 2005 01:46 PM
Knight1
Sep 3, 2005 06:47 PM
91accordwagon
Feb 19, 2005 06:48 PM
