do any of you use the msd activation switch for your vtec?
Old Aug 13, 2002 | 06:51 PM
civbeater90's Avatar
Default do any of you use the msd activation switch for your vtec?
just curious if any of you use this?how is it working for you?
Old Aug 13, 2002 | 09:58 PM
RenoRacing's Avatar
Default Re: do any of you use the msd activation switch for your vtec? (civbeater90)
it's great, i have a rpm activated switched and then instead of the pills i have the module selector that varies from 4600 to 6800 so i can play with my vtec crossover with the turn of a know
Old Aug 13, 2002 | 10:10 PM
ViperRedCRX's Avatar
Default Re: do any of you use the msd activation switch for your vtec? (HavokRacing)
i'm using one, and have vtec set at 4800...it works great
Old Aug 13, 2002 | 10:41 PM
Mugen Dom's Avatar
a buddy of mine is running a pr4 ecu from a 90 teg
Old Aug 14, 2002 | 02:56 AM
LsDXRacer's Avatar
Default Re: do any of you use the msd activation switch for your vtec? (jdmb18hatch)
whats better a MSD crossover or getting the right ECU??
thanks
Old Aug 14, 2002 | 04:29 AM
zCivic's Avatar
I've been pretty happy with my MSD switch. I have pills 4k-4800 run V-tec a 4k at track and usually run 4600 on roads. Its good for a temporary motor swap because building a B18A swap at the house and didn't want to go with entire ECU swap (wiring changes) seeing will be going with another OBD0 ECU. If you go with the new ECU have to change ECU plugs and distributor. If you go with a Z6 you have to cut the distributor to make it work if you go with the Y8 the Diz will bolt up. Get a Y8 if you can better intake manifold also.
Old Aug 14, 2002 | 05:22 AM
june's Avatar
Default Re: do any of you use the msd activation switch for your vtec? (zCivic)
I have it done to my hatch works great!!!!
Old Aug 14, 2002 | 06:42 AM
88_SC_CRX_Si's Avatar
New User
Default Re: do any of you use the msd activation switch for your vtec? (LsDXRacer)
By far, getting the right ECU... hehehe
Problem with a non-VTEC ECU's, is that you don't get the VTEC timing MAPS, to go along with it. When comparing a P6 with P28, the fuel tables are the same with "very" few changes. However, it's when you get to the timing MAPS, it's a whole different story. Same goes with a V-AFC, you can only modify the fuel MAPS per say, not the timing where you need it most.
I am using a Summit's RPM Switch, really can't complain about it, as long as it keeps working...
Go hear for some info... This for a Z6 Mini-Me head swap tho:
http://geocities.com/chipman_13/mini-me-parts.html
[Modified by 88_SC_CRX_Si, 7:47 AM 8/14/2002]
Old Feb 16, 2010 | 06:55 PM
TMC_EF's Avatar
Can anyone tell me how to wire up thr vtec to the activation switch othe tha the summit one?
Old Feb 16, 2010 | 07:49 PM
TMC_EF's Avatar
bump som one.........
Old Feb 16, 2010 | 07:53 PM
D16SiHatch's Avatar
helpless much?
took 2 seconds to find
http://www.sstang.com/techfiles/sumitt_rpm_switch.pdf
Old Feb 16, 2010 | 08:27 PM
TMC_EF's Avatar
is it the same for msd?
bobbymoon
Jun 11, 2009 04:34 PM
HatchMo
Jun 24, 2005 08:52 PM
iphatcrxi
Dec 6, 2004 08:30 PM
mellon
Sep 13, 2004 06:36 PM
mycvc8u2
Jun 14, 2003 06:29 PM
