Transmission Problems....
Old Mar 27, 2009 | 06:17 AM
924doorEG's Avatar
Default Transmission Problems....
When i push the clutch pedal in the grinding noise goes away yes i know its the bearing inside the tranny....but when going in a parking lot very slow i hear grinding also....and when downshifting i can hear a grinding/whining noise coming from the tranny...i need to swap out the old D15b and tranny for a new one but until then any ideas on what fluid i should change it with?
Old Mar 27, 2009 | 07:45 AM
hondachris1994's Avatar
Default Re: Transmission Problems....
Your throwout bearing is shot, changing the fluid isnt going to do anything 4 u.
Old Mar 27, 2009 | 08:19 AM
teamworxek9's Avatar
i second the throwout bearing is bad.
Old Mar 27, 2009 | 09:20 AM
dpaton's Avatar
Um...with the clutch in, if it gets quiet, that's the ISB. TOB is when it's quiet when the clutch is out....
Old Mar 27, 2009 | 01:23 PM
924doorEG's Avatar
how long do you think i have on it?
Old Mar 27, 2009 | 06:41 PM
5 days 22 minutes and 33 seconds but really I wouldnt go 2 much longer with it like that.
Old Apr 24, 2009 | 07:31 PM
93DelSol-S's Avatar
New User
hey guys i have a 93 del sol s model and im having similar problems. first my clutch is slipping and when i take off slowly on first gear it makes noise. in addition on higher rpm it pops out of gear on its own ..is there any hope or should i just replace the tranny??
Old Apr 24, 2009 | 07:34 PM
trustdestruction's Avatar
ISB
throwout bearing is the opposite (makes noise when clutch is disengaged/pedal pushed down)
93DelSol-S:
sounds like shift fork
Old Apr 24, 2009 | 10:03 PM
twiztid_989's Avatar
i think ur clutch and flywheel unbolted from ur crank my eg9 did tha same thing
Old Apr 24, 2009 | 11:08 PM
silentone's Avatar
if it sounds like these:
http://www.youtube.com/watch?v=rQppj3KlY2A
http://www.youtube.com/watch?v=xX5-UD1k19A
then it is your isb.
in the first vid, you can hear that grinding/whining noise when i disengaged and engaged the clutch.
in the second vid, you can hear the same noise as i was driving through the gears.
Old Apr 24, 2009 | 11:12 PM
TravisCadello's Avatar
that sux. when i did my first engine swap, when i pulled the auto tranny out my EG 3 of the dam flywheel bolts had back out a lot.
Old Apr 24, 2009 | 11:44 PM
that sounds like the flywheel bolts
Old Apr 24, 2009 | 11:46 PM
sp00ledbseries's Avatar
damn ive never heard one that bad
Old Apr 27, 2009 | 09:50 PM
Boost it's Avatar
i have a spinning rattle sound under throttle....my guess which im trying tomorrow is putting grease behind the shift fork on the TOB
Xxcivic97xX
Aug 22, 2010 07:22 PM
jimbrown
Jul 17, 2007 12:35 PM
TiredToyotaDriver
Jan 14, 2006 07:26 PM
fkguitar
14
Jul 5, 2005 01:46 PM
