quietest 2.5" straight through exhaust?
i been recently thinking about selling the car especially since the exhaust has gotten too loud.
now im thinking if i should just get a new exhaust.
what is the quiestest/stockest looking 2.5" exhaust for the eg hatch??? complete kit is preferred over custom. thanks guys
The Apexi WS2 and RSR exmag are both 60mm which is ~2.36". That should be big enough depending on your application but if you are bent on 2.5" on bigger than I don't know of any off the shelf reasonable quiet exhausts on the market. Custom most times ends up being cheaper depending on where you go.
If you have 2.5" exhaust now you could get a WS2 muffler welded on and that would quiet it down substantially...
Of course it does. Straight-through design allows for a fiberglass packing around a perforated tube that exhaust gases travel through. The more packing, the less sound. Also, you should be using a resonator in conjunction with your muffler for further sound refinement. That all being said, Magnaflow has a huge selection of mufflers, all straight-through design, varying in size and sound control.
big-cat
Mar 20, 2007 08:05 AM
