using a type r cat for my gsr???
Old Mar 26, 2009 | 10:27 PM
mannydhanju's Avatar
Default using a type r cat for my gsr???
I want to run my buddy's jdm type r headers on my gsr... so i know i need a type r cat... but i need to know will it clear the oil pan and so forth and when i bolt up my exhaust which is a greddy exhaust for gsr will it bolt up to the back flange that comes off the cat or is the flange too big... and i need to know where to get a good cat from not too expensive and not too cheap...
thanks Manny
Old Mar 27, 2009 | 01:40 AM
racebum's Avatar
Default Re: using a type r cat for my gsr???
an OE jdm cat is what you need. call steve at hmotorsonline and see if he has any left
Old Mar 27, 2009 | 07:31 AM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
It will clear, jdm itr is 2.5 I believe, so the cat has to be 2.5 as well. The Greddy should bolt right up, my stock one did.
Old Mar 27, 2009 | 08:59 AM
JdmTypeRdc2's Avatar
You should have no problems with a jdm itr cat. It has a 2.5 inch inlet, good for the 2.5 inch collector from the header, and the outlet of the cat is 2.25 which should bolt up to a greddy exhaust.
Old Mar 27, 2009 | 09:29 AM
cool thanks for the advice fellas
Old Mar 27, 2009 | 10:43 AM
hmoobhero's Avatar
what? i thought the jdm itr cat is 2.5 both ends? why did honda make it like that cuz wont that bottle neck the flow? which is bad right?
Old Mar 29, 2009 | 10:53 AM
MEM10teg's Avatar
New User
you will have no problems
93(Civic)EG6
Oct 2, 2007 08:21 PM
DutchITR1689
Feb 20, 2005 06:09 PM
BSQ
Apr 6, 2003 12:55 PM
B_1_8_hatch
Mar 20, 2003 10:56 PM
CPR
Jul 21, 2002 06:50 PM
