Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
help car is shaking
Old Mar 26, 2009 | 07:53 PM
aLlmoTorcoUpe's Avatar
Default help car is shaking
okay i have a 01 civic ex coupe, and i like to know what is worng with my car. the motor is shaking like a tank. what wolud be the reason. the car is fine when driving but when you stop or start the car the whole car is shaking. is it the motor mount or what???
Old Mar 26, 2009 | 08:10 PM
toyomatt84's Avatar
Sanji
Default Re: help car is shaking
It's not uncommon for the d17a2's to develop a worn motor mount.
Old Mar 26, 2009 | 10:52 PM
will i took i close look at the motor mount. the front and the tran, side is out. i may need to change it but i'm not sure about the back and the right side motor.
Old Mar 27, 2009 | 08:14 AM
spoonfedcrx's Avatar
Have someone get in your car. Set the e-brake, put car in gear and power break it. You stand outside under the hood with a flashlight, mirror or whatever else is necc to get a good look at all the mounts. There may be cracks and whatnot that you cannot see without torquing the engine.
Old Mar 27, 2009 | 09:40 AM
okay so if the motor is shaking like crazy, then it should be to the motor mount, or something esl. like timing belt is off, or value need to read set.?
em2dreamer
May 12, 2009 10:36 PM
kixcrx
Sep 23, 2007 02:30 PM
Rocks
11
Jul 23, 2004 11:19 AM
01PYITR
Jun 30, 2002 02:58 PM
