vtec wire colors
Old Mar 26, 2009 | 05:18 PM
90Rexx's Avatar
Default vtec wire colors
ok so on a B18c on your vtec pressure switch, you have 2 wires.... what color wires are they? and which wire is the ground and which wire should go to the ECU connector? also a pic would be helpful because i think the wires are incorrectly colored on my harness. <--- in other words, is the ground or the ECU wire closer to the top of the plug?
Old Mar 26, 2009 | 05:40 PM
90Rexx's Avatar
Default Re: vtec wire colors
ttt... doing my harness right now... need help
Old Mar 26, 2009 | 06:58 PM
bmxmacdaddy's Avatar
i did some searching for you.... hope this helps.
http://hondaswap.com/hybrid-eg-ek-dc...ivic-ecu-6455/
If this doesnt work you should, if not already, buy a haynes or chiltons manual with the wiring diagrams. Also you may go to a local parts store and see if you can pick up one of those little cheapo books that give the whole diagram.
oh and the black wire is, USUALLY the ground on automotive stuff, but dont hold me to that in this case.
Old Mar 26, 2009 | 07:07 PM
trustdestruction's Avatar
http://hondacivicforum.com/forum/showthread.php?t=73241
Old Mar 26, 2009 | 10:32 PM
chero112's Avatar
Originally Posted by trustdestruction
great link.......Help me out
Old Mar 26, 2009 | 10:36 PM
if you have OBD1, it's orange/blue
blue_hatch
Dec 18, 2006 08:32 PM
phanatic
Sep 11, 2006 04:20 PM
dpine
Apr 8, 2005 07:11 AM
CivicSiRracer69
Oct 31, 2004 11:17 AM
lightningd
Apr 4, 2003 01:30 PM
